Error: Initializing form...
1625
11
09-19-2023 11:22 AM
KevinMcMaster2
New Contributor III
"TypeError: Cannot read properties of null (reading 'attr')" - Is anyone else getting this new error on existing surveys? Seems connected to "dropdown" type questions... Deleting the existing question and re-adding it fixes the issue, but that doesn't help existing surveys.
IsmaelChivite
Esri Notable Contributor
 A fix to this issue has been deployed. @Tim_Ultee @KevinMcMaster2 @LindaLin1 @cbolen: your survey should now continue working without further action from your side.
KevinMcMaster2
New Contributor III
@IsmaelChivite  @JamesTedrick  - thank you!
JamesTedrick
Esri Esteemed Contributor
We are aware of this issue and looking into it.
cbolen
New Contributor III
Following.  Experiencing the same thing on an existing Survey.
TimShortley
Seconding this issue as I've got an existing survey out that is not capturing responses. This behavior appeared simultaneously with this error.
LindaLin1
My existing survey having the same error occurred from yesterday, form worked in field map but not in web browser. same error message as above. the form was working completely fine previously.
Please help to fix the issue as soon as possible.
Many thanks
Tim_Ultee
New Contributor III
Having the same issue with one of our surveys as well, yet not another similar survey. Hoping this is fixed or the solution is identified quickly.
IsmaelChivite
cbolen
New Contributor III
Thank you, it appears to be back to normal!
Tim_Ultee
New Contributor III
Confirmed, thanks Ismael.
