Everytime I change language a new "Time" field appears in the form: Bug?
724
06-15-2021 02:34 AM
PanGIS
Hello everyone,
- I created a form with double language.
- The dateTime field is set as default  now() [but I tested with a black field and it is the same]
- The issue occurs only on Web Form
is this a bug?
Thanks!
This is the appearance when I open the Web Form:
I change language and this is the result:
the more I switch, the more field are added:
I removed the default now() but nothing has changed.
Tags (3)
Shwu-jingJeng
Hi PanGIS,
Could you provide more information on the following questions?
1. What version of Survey123 Connect did you use to publish?
2. Are you publishing the survey to ArcGIS online or a portal?
3. What two languages are you using to test this?
4. Did the problem occur on any web browser or a particular browser?
