Hi, I’m looking for suggestions for an error I’m getting in Survey123. I have a survey that uses the pulldata() function to populate fields from a feature service. When I test the survey on the mobile app, I am unable to send the form, getting a Send Error that says Operation rolled back.
I have tried removing bind::esri: constraints and I have ensured that the mobile Survey123 app and the Survey123 Connect apps are the same version. I have tried changing the publishing options for both Enable Sync and Use global ID parent keys in repeat relationships. The app works as expected from browser.
I've attached an excerpt from the log.
Tori
