I try to pass a globalID from Collector to Survey via URL parameters. Everything works fine except the GlobalID is always in uppercase in my feature service, but once it goes into an esri.fieldtype:GUID in Survey123, it turns into a lowercase.
I noticed that in iOS, it is passed as an uppercase text, but not in Windows10 tablets (collector and survey123 up-to-date).
The only way I found is to create an "incoming" field with fieldtype=null that stores the value passed by Collector, and then my GUID field that calculate the first AND with InputMask= ">XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" to ensure every lowercase letter is set to uppercase.
BUT this only works if the field type in Survey123 (not the esri.fieldtype) is set to "text" AND is NOT readonly AND the user enters into the field (by clicking the field without changing anything) when doing the survey.
This is the only way Survey123 sends Uppercase GUID.
Otherwise, Survey123 is always sending a lowercase GUID.
Any idea ??
