Have downloaded the newest version of Survey123.When i try to upload my data i just get the message Getting Service Information. It never uploads.
729
03-15-2017 08:00 AM
CeciliaVentocilla
I deleted my survey that would not upload, closed out of Survey123, went back into Survey123 and downloaded the survey again and not worked yet
JamesTedrick
Esri Esteemed Contributor
Hi Cecilia,
The message you are seeing can have several causes.  One of the most common ones is having expired login credentials - can you log out and log in on the app?
CeciliaVentocilla
Thanks, I puted my credentials againg and it Works.
JarinStewart
Hi James,
I am having the same problem as Cecilia. I have had all of my users sign out and sign back in prior to sending data. Still they get "Getting Service Information". We have verified that they do have connectivity, but it may be slow because it is in Northern Ontario, Canada. Does the connection time-out, or does it test connection speed before transferring data?
Jarin Stewart
