i'm creating a survey with a repeating section and i want it to be created as a related point feature rather than a related table.
i have managed to get this bit to work by just adding another GeoPoint into the repeating section, but i also want it to default it to the same location as the main GeoPoint , i have tried adding a calculation to the second GeoPoint pulling the xy from the first but it doesn't seam to work the point just stays at 0,0
my calculation against the second geopoint is as follows where [GeoLoc] is the first geopoint
pulldata("@geopoint", ${GeoLoc}, "x") + " " + pulldata("@geopoint", ${GeoLoc}, "Y")
i also added in an X & Y field into the repeat section using the pulldata and it populates matching that of the main point
has anyone else managed to get this to work?
thanks
Stu
