Have a survey that is pulling existing records into the Inbox. There is an image question that pulls down images. The survey user can add more images to this question.
What I would like to do is make adding at least one more image compulsory. Setting a required status of yes on the question doesn't work as the conditions are met already.
I feel like there should be some way to achieve this using calculations, constraints and the count-selected() function but haven't appeared to get it to work successfully of yet. Maybe if I can't get it to work on the image question, I can put two null questions in with different calculation modes and have that act as the constraint?
Has anyone tried this before and got it to work?
