All,
I am having an issue with a google maps url causing data errors that is prevent editing of the survey data. The Url that i am using is so the crews editing existing data can launch google map for driving directions. I originally copied the following expression esri's support page. FAQ: Is it possible to view a geopoint location from Survey123 Connect for ArcGIS in Google Maps?
The expression in my survey form.
concat('<a href="https://www.google.com/maps?daddr=',pulldata ("@geopoint", ${Gps_Coord}, "y"), ',' ,pulldata("@geopoint", ${Gps_Coord}, "x"), concat('&ll=">Click to open google maps</a>'))
The issue seems to be the " qoute marks for "https and =">. This is causing some sort of data error that makes it impossible to edit any of the attributes for the survey. If i remove the quotes then there is no data error but then the link no longer works in the survey field app. Has anyone else experienced this issue? I have esri support looking into it.
Josh
