Hi, our ArcGIS Enterprise is version 10.9. I uninstalled 3.15 version of the Survey123 Website from the Enterprise server, hoping I can install the newer version on top of the older Enterprise.
Can I install the updated 3.19 Survey123 website on an older ArcGIS Enterprise?
Kurt
This KB seems to indicate that you should be fine.
While the installed Survey123 website has been tested successfully with ArcGIS Enterprise portal versions 10.5.1 and later, each release officially supports ArcGIS Enterprise versions that are in the 'General Availability' phase of the Product Life Cycle at the time of release.
I'm sure you've already noticed this, but I will mention that 10.9 will be retired in four months (June 2024).
Thanks for replying! I'll keep pushing into it.
