"The definition of insanity is doing the same thing and expecting a different result": I have rebuilt everything from scratch, confirmed relationships, enabled arching, globalids, and sync on the feature class. I have done nothing but "create a survey from a feature service" and then instantly try to publish the survey from Survey123 Connector and get the below:
We are using latest ArcDesktop; ArcServer (unfederated) with Portal, Latest Survey123, all in Microsoft Azure. I can easily work with a single layer with an attachment, publish and collected photos. This 2 tier relationship is not working.
My MXD looks like. The only layer it will not let me pull in is the relationship between SUR_ROOMS_PLUMBING & __ATTACH
The below lets me publish Survery123 to Portal but obviously is not good due to lack of attributes.
This throws me the aforementioned error. I have also removed and tried to publish on every single stand alone "type". Having a "Type in the repeat is not allowing a publish and is shown the above error.
