Hello everybody.
I'm having a problem displaying the maps linked to the form when I edit an Outbox record (webmaps).
When opening to collect a new record, edit a record in Inbox or Drafts, the correct webmap is displayed. However, when saving this record in the Outbox and returning to edit it, the webmap linked to the search disappears, and only the webmaps shared with my Portal are displayed.
Edit in Collect/Inbox/Draft
Edit in Outbox
I encountered a similar issue, however, the filling was done offline, and, in my case, the problem occurs even with an internet connection. Link: https://community.esri.com/t5/arcgis-survey123-questions/using-a-linked-map-in-survey123-outbox/td-p...
I believe it is not a connectivity problem (as, in both cases, I have active internet), nor with sharing the webmap (as, in both cases, I am logged in with the same user and, even with the user who owns the search , the problem occurs).
Any suggestions to fix this issue? Thanks in advance.
