Hi All
I recently required a form to be updated to include a repeat. I realized I could not add the repeat without republishing the form so i decided to add the new table and relationship via the REST API Addtodefintion. I was successfully able to republish the form and survey123 connect recognized to new table and the relationship however when I try to submit a form now I am met with the following error (taken from .sqlite file)
{"code":1003,"description":"Operation rolled back.","tableId":0},{"code":1003,"description":"Operation rolled back.","tableId":0},{"code":1003,"description":"Operation rolled back.","tableId":5},{"code":1003,"description":"Operation rolled back.","tableId":5},{"code":1003,"description":"Operation rolled back.","tableId":5},{"code":1003,"description":"Operation rolled back.","tableId":5},{"code":1003,"description":"Operation rolled back.","tableId":3},{"code":1003,"description":"Operation rolled back.","tableId":3},{"code":1003,"description":"Operation rolled back.","tableId":3},{"cod N Oe":1003,"description":"Operation rolled back.","tableId":1},{"code":1003,"description":"Operation rolled back.","tableId":1},{"code":1003,"description":"Operation rolled back.","tableId":1},{"code":1000,"description":"Cannot insert the value NULL into column 'globalid', table 'db_19692.user_19692.service_5822ca4cbf4645d2acd99c69fb8d5c8c_DEVIATION_REVIEW'; column does not allow nulls. INSERT fails.\r\nThe statement has been terminated.","tableId":6}]{
has anyone any ideas as to what may be the issue? @Tedrick
