Are there any known issues using a choice list to populate a geopoint question from a select_one_external on Portal?
I have 25K addresses to pull in from a choice list. To speed things up, I am trying to use cascading and external selects.
The survey works using a choice list in AGOL using select_one/choices, just a bit slow, load time ~8 seconds.
Does NOT work in AGOL using select_one_external and external_choices.
Using the same XLS Form....
Publishing failed in PORTAL using select_one/choice list and select_one_external/Myexternal_choices.
My thinking was that it is stored as a text string in the items.csv file, therefore, causing issues. I have tried changing the bind::type not the bind::esri:fieldType with no success. I get an ErrorCode 500 when trying to publish to PORTAL and publishes fine to AGOL just that the dropdown does not provide any selectable items.
Any thoughts as to what may be causing this?
From survey
type | name | label | appearance | choice_filter |
select_one_external address | addresses | Select Address from List | autocomplete | parish=${parish} |
From external_choices worksheet
list_name | name | label | parish |
address | +029.9329_-90.3637 | 103 1ST ST LULING LA | SCP |
address | +029.9328_-90.3636 | 105 1ST ST LULING LA | SCP |
address | +029.9338_-90.3640 | 105 1ST ST LULING LA | SCP |
address | +029.9338_-90.3639 | 107 1ST ST LULING LA | SCP |
