I see 2 errors that in the syntax of your code that may be related to the problem:
1) The correct one would be "@json" (not "@jason")
2) When calling a specific attribute of the queried layer, the "attributes" group must be separated from the attribute/column name by a dot (not a colon).
I believe that by making these two corrections your code will work correctly.
