I have created a survey that is preloaded with data from our enterprising data base. The survey is setup to use the inbox. The user can pick an existing survey from the inbox and edit a subset of the fields in the data. There are some fields that I want to display for contextual information but do not want the user to have the ability to change. If I set the readonly property to 'yes'; the data is not displayed.
How do I get read only data to display on the form when editing an existing survey?
