Hi Folks,
I'm going crazy trying to make my reports work again. They were working fine, till I modified some attributes on the custom template. The source of the error seems to be the map setting. If I remove the map tag, the report get generated just fine.
In my custom template, I have this line to make my map show:
${Poligono_Vuelo | map:"588eb299f5b346fcb4143621060c0888" | size:400:300}
Which is a geotrace polygon. The error I receive is (see attached screenshot):
An error occurred while generating reports.
An error occurred when rendering by the report engine. Failed to print map for ${Poligono_Vuelo | map:"588eb299f5b346fcb4143621060c0888" | size:400:300}. Connection timed out after 120000ms
I tried changing the map to another public vector map with no success. I even tried the very basic map option:
${Poligono_Vuelo | size:400:300}
with no success at all.
What is wrong? It was working but now isn't. The problem is the generating the map image on the report. How can I debug the problem?
Thanks!
