Report Template - Filter Repeats Used in If Statement
329
01-23-2023 05:41 AM
AnthonyJonesRSK
Occasional Contributor II
Within the report template documentation here it suggests;
  • ${if (repeat1 | getValue:"count")>=3} displays the section only if repeat1 contains three or more records.
My question is whether it is possible to filter the repeat used in this if statement so I get a count for the number of repeats where a certain answer was given in a question in the repeat? I'd like to display a section of the report only if at least one repeat record has a particular answer in it.
I've tried various options here including where clauses documented here, so you have something like this;
${if (repeat1 | where:"weather='sunny'"| getValue:"count")>=3}
but this doesn't work (I assume it's limited to summary sections?) and no other options I've tried have worked. So I just want to know if this kind of filtering is possible and if so what is the syntax?
Any assistance would be much appreciated.
Anthony
@IsmaelChivite @BarbaraWebster1 @Anonymous User
