Hi community,
I'm a bit confused because i tried a lot of combination in a last few days, but something goes wrong, so I need you help.
I have a task to prepare a form in a 2 languages (ro and ru), which should be used in web app. Form is a bit sophisticated so I use Survey123 Connect (version 2.7.72) to prepare application form.
In a first scenario a set default language in xml, in this case select one question doesn't work in any language in a web app (exception Cascading selects), but in same time in Survey123 app works great in any scenario. (looks at the attached image)
In a second scenario I don't set any language in xml, in this case select one question works in web app with default language but doesn't work in second language (looks at the attached image).
I just need to prepare form which will work fine in both languages. I make some mistakes or is a bug?
Thx in advance for your help.
P.S. I attached xml schema but without .csv table whitch I use to populate some columns.
