Hi All,
On the 27th of December everything was working fine and today (30th) our field crews are all getting an error - send error string or binary data would be truncated - on submission. There have been no changes to the survey. Obviously the error referrers to a response not fitting a field length. Survey123 version 3.7.57.
Everything seems to look fine, and I am not aware of any Esri changes between the 27th and the 30th. Is there an easy way to identify the issue in the xlsx form? It would be good to be able to submit a record and ignore the error, letting the data truncate, so I could see the output...
Really just wondering if there have been any changes recently that may cause a form to fail since the 27th, and the easiest way to identify the issue within the form.
___________________________________________
UPDATE:
I found where the form was getting stuck - still have no idea why this calculation was working on the 27th and not working on the 30th... I ended up adding a Note field to every Hidden field to see exactly what was being written out.
I was extracting the Week value from the Date field using this calculation:
format-date(${date},'%W')
I also extract the Month, Quarter, and Year - they are all still working fine. Just Week is no longer working as of today.
We have been using this for ages with no issue. It seems that the 30th and 31st of December just don't work. Brett Stokes can the team have a quick look at this behavior (30th & 31st of Dec)? Also seems to be an issue with the 'week-number' appearance setting. Thanks.
____________________________________________
Jamie.
