Side by side photos from a repeat in a Survey123 report?
773
03-15-2022 11:00 AM
BryceHancock
Helllo, is there a way to show photos side by side from a repeat in a Survey123 report yet? I tried using a table but it places the photos, one after the other down the page, instead of across. Thank you.
Katie_Clark
MVP Regular Contributor
I was just researching this the other day, and from what I can tell it's still not possible to put photos from a repeat within specific cells in a Word doc template. 😞
For one survey in particular I opted to have individual photo questions (one for each cardinal direction), so that I could put them within a table in the template and get the formatting just right. But I have many other surveys where that's not a feasible schema and repeats are necessary. So yes, I hope they implement this soon!
Best,
Katie
“The goal is not simply to ‘work hard, play hard.’ The goal is to make our work and our play indistinguishable.”
- Simon Sinek
GIS_Fox
I've tried this before with multiple photo attachments but just like @Katie_Clark I hope it's a customizable option for reports and templates soon because I've only got it to load in page by page. This is fine but it does look less professional. Right now any multiple photo reports or word docs simply load out the next photo to the specifications given in the template. Usually with some edits you can change how it displays but I have yet to find how to do a "fill in the table/graph/chart" kind of template workflow. It's a great post to add to the idea section if it's not there already, you've got my kudos for it already.
Best,
Jansen Lyons - Records and GIS Section - Public Works - City of Rio Rancho, NM
EmmaHatcher
I found a workaround to accomplish this! You can highlight your photo attachment repeat lines in your report template Word document, including the repeat header and closer lines, and then format your layout as two columns. See pictured below. I tested on 4+ photos and it consistently stacked them in columns without affecting the rest of the report.
