Hi I've got a web map used in Collector and a popup configured to send an email to a distribution group when a link is selected from the web map. A Power Automate flow runs and sends the email. What I'm having trouble with is getting a date field to display a human readable date in the email. Inside Power Automate I tried to use a Compose step to first format the date field coming from dynamic content with a "formatdatetime(triggerBody()?['feature']?['attributes']?['FIELD'],'yyyy-MM-dd')" and this just about gets it but not quite. Power Automate gives me the following error:
“Unable to process template language expressions in action 'Compose' inputs at line '1' and column '2849': 'The template language function 'formatdatetime' expects its first parameter to be of type string. The provided value is of type 'Integer'. Please see https://aka.ms/logicexpressions#formatdatetime for usage details.'.”
I tried to convert the integer date to a string without much luck, but maybe my syntax is wrong. Getting the date to display sure seems like it should be easier. Any ideas what I am missing?
