Hi All,
From this article (Appearance—ArcGIS Survey123 | Documentation), under the IMAGE section (4th paragraph), it says:
"To limit the user to only one or two forms of image capture for annotation, set bind::esri:style for that question to method=camera, method=browse, or method=map, or any combination of two of them, for example method=camera,browse. The question disables all other forms of providing an image."
Does 'method=' apply to bind::esri:style or body::esri:style? I thought I may have missed bind::esri:style as I have an older form, but when I checked the latest template (Survey123 Connect v3.10.239) I didn't see bind::esri:style there either.
It works when you apply method= to body::esri:style, so is it just a typo in the documentation? Thanks.
Jamie.
