Survey123 Connect Issue with Display
1468
5
06-21-2017 11:20 AM
AndrewBartshire1
I am having issues with using Survey123 Connect on one specific computer in our office. The program only displays a small portion of the text (in some cases every other character in a word) in both form preview and the main menu. I have tried uninstalling and re-installing survey123 several times and have the most current version installed. The computer is running Windows 7 Professional, has a 3.40GHz Intel i7-2600 Processor and 12GB of RAM. Do you have any ideas what might be causing this glitch? I've attached screen shots of the issue.
JamesTedrick
Esri Esteemed Contributor
Hi Andrew,
This looks like an issue with the OpenGL drivers on the machine.  Can you check to see if the latest drivers for the graphics chips/card are installed?
JamesTedrick
Hi Andrew,
AndrewBartshire1
Updated the drivers and the display looks normal. Thanks for the help!
MichelleWilliams1
Help. Same question.
I downloaded/installed OpenGL  (430.86-desktop-win8-win7-64bit-international-whql.exe) and I still can't see the top of Survey123. Am I doing something wrong?
JamesTedrick
Hi Michelle,
Could you modifying the Windows shortcut for Survey123 Connect to switch the rendering engine?  Right-click on the shortcut, select 'Properties' and at the end of the Target setting, add a space and then
--renderingEngine=angle
See the attached image.  Information about manually setting the rendering method is in Frequently asked questions—Survey123 for ArcGIS | ArcGIS
MichelleWilliams1
It was my drivers, thanks for the quick reply, I also modified my Windows shortcut.
