Unfortunately, it does not work. I want the model name to be readonly if the the status is 'ekfb_rejected'.
This is my xls
After publishing the form I can still edit the model field in the embedded xls form in the dashboard
The xlsform is embedded in the dashboard with the url ending with
/portal&mode=edit&autoRefresh=true&globalId={globalid}
The xlsfrom reads only the entries that have been already collected. It is not designed to submit new records.
