Survey123 Re-Send Survey Bug
722
07-17-2020 12:33 PM
RyanUthoff
Occasional Contributor III
I have discovered what I believe to be a bug in Survey123 that I am able to replicate in multiple forms in two different ArcGIS Enterprise (10.6.1) environments.
In my survey, I have a hidden field with a "bind::esri:fieldType" of "esriFieldTypeInteger." Just for reference, we populate that hidden field from a URL in a web map.
When we submit a survey with that field being null, it will be written to the data store table as being null (and I can verify that by looking in the hosted feature service and seeing it being null). However, if we edit and re-submit that existing survey through Survey123, it will change the value in the hidden field from null to 0 (again, by verifying that value in the hosted feature service).
Luckily, if a value is already populated in the hidden field and then you re-submit a survey, it will not change the field value to 0. It will maintain the value. It only changes the value to 0 if the original value is null.
Is this behavior to be expected? I don't see why the field value would get changed from null to 0.
Tags (4)
JamesTedrick
Esri Esteemed Contributor
Hi Ryan,
I did some additional work - it appears that this is being caused by a discrepancy between the bind::Esri:fieldType and the bind::type field.  Updating the bind::type field to int (to match the integer field type) addresses this issue.
JamesTedrick
Hi Ryan,
I can replicate the behavior you are describing.  Can you file an issue with Esri Support so we can better track who this is impacting?
RyanUthoff
Thank you for your response. Yes, I will submit a ticket through Esri Support tomorrow. I'll reply back with the support number and/or bug number once I have it. Thank you!
JamesTedrick
Hi Ryan,
RyanUthoff
Thank you for the additional information. I set the bind::type field to int and it looks like that fixes the issue. Thank you!
