I have a survey form with nested repeats structured as:
- Project
- Plot (repeat)
- Feature (repeat within Plot)
- Survey type (question)
- Rating (question)
I created a report template that will provide totals for all Projects surveyed in a year. Part of the report contains a section that tallies the # of different ratings (e.g. excellent, good, etc.) for each survey type (e.g. CB, CD, FB, etc.).
If a survey type does not exist for a particular year then I want the ratings table to be hidden on the report.
I've tried using:
${#rptFeature}${if SurveyType=="CB"} |
Survey Type | CB |
# of Features Monitored | ${rptFeature | where:"SurveyType='CB'" | stats: "count,objectid"} |
# Excellent | ${rptFeature | where:"SurveyType='CB' and FeatRating='excellent'" | stats: "count,objectid"} |
etc...... | etc........ |
# Failed | ${rptFeature | where:"SurveyType='CB' and FeatRating='fail'" | stats: "count,objectid"}${/}${/} also tried ending with ${/}${/rptFeatures} |
but end up with a table being repeated for each of the selected survey type records
If I remove ${#rptFeature}${if...}....${/}${/} and use the following syntax, I get the correct totals for each survey type.
Survey Type | CB |
etc.... | etc.... |
# Failed | ${rptFeature | where:"SurveyType='CB' and FeatRating='fail'" | stats: "count,objectid"} |
However, if the survey type does not exist (i.e., FB), the table for that non-existent survey type still persists in the report.
I cannot seem to get the syntax right for creating a table that tallies the total ratings for each existing survey type from the nested repeat. Any suggestions?
I'm using Survey123 Connect v 3.14.281 to create the form. I'm attaching my xlsxForm, report template, and 2 generated reports with different survey type scenarios. I've pared down the questions from the original to focus on the trouble spots.
