Hello Zach,
Thank you for your reply.
I thought I changed the setting, but I might have done it wrong timing. I'll test it today.
And for the hyperlink, I played with the ' and ", and nothing works. The hard copy hyperlink is for that purpose. I switched ' and " and it actually both work. To create the hyperlink using concat, I had to use " for the <a ref> tag. Since the link is working in connect, I don't think the issue is the <a ref> tag. It's something with the webform.
I forgot to ask one question. This may be related to the objectID & globalID. When I open the form with the ID, the past data form shows up in edit mode. However, I can't submit the change. I changed the numbers in the survey, and hit the submit button, nothing happened. I checked the data and no change.
My company usually uses Survey123 field app, but for this one, we are trying to develop the survey using your COVID-19 GIS Resources, and because not all the managers are tech-savvy so we decided to use the webform. And they want to fix the survey when they made a mistake, so I need to add this survey editing function to the form ASAP.
