Using select_multiple with Cascading Sheets
680
11-27-2018 08:59 AM
HeathAnderson
Occasional Contributor II
Is it possible to use the select_multiple option with cascading sheets?  For example in the attached Form if I was going to visit several different cities in different states throughout Australia would i be able to submit 1 survey select_one "Victoria" and then be able to select_multiple cities from those only in Victoria "Melbourne,Ballarat"
JamesTedrick
Esri Esteemed Contributor
Hi Heath,
Cascading selects are not supported for select_multiple questions.
JamesTedrick
Hi Heath,
AndrewHargreaves2
Occasional Contributor III
I have this need too...
