When Does A Choice Question Gets a Coded Domain Value?
872
12-14-2016 01:13 AM
WengNg
Just a little background on my question, I always thought that a select_one question will always store the choice values into a domain in AGOL and the labels as the description. However, I have two select_one questions and one of them has a domain but the other one doesn't. The only difference between the two is that one of them had a choice filter applied to it.
My question is that does choice filters or any other dependencies affect how Survey 123 stores domain values?
Weng
IsmaelChivite
Esri Notable Contributor
Hi.
  Geodatabase domains are automatically created for select_one questions when you publish your survey, except when your select_one has a choice_filter (cascading select) associated to it.
IsmaelChivite
Hi.
