Export Track to Shapefile doesn't export time
366
11-02-2022 05:21 AM
LiamHarrington-Missin
Occasional Contributor II
Hi all,
From what I can tell, if you use the "export--Shapefile" option in arcgis online to create a permanant record of the track log created in Tracker it strips out time.  I've done a few tests, as I couldn't beleive it was happening but as far as I can see, all my date/time fields have been reduced to just date.  If I export as a CSV it works as expected.
Can someone else confirm this is happening and also whether this is meant to happen?  It makes the data pretty useless without time.
Cheers
Liam
