Field Length Error Applying Asset Package to Enterprise Database
922
6
10-07-2021 05:15 AM
SMW_GIS
New Contributor III
Hi. I'm trying to apply an asset package to an enterprise geodatabase and running into this error shown in the screenshot. I've checked both fields in each feature class, and they're both 64.  Not sure what is happening here. Capture.JPG
LoganSuhr_PSE
New Contributor III
This looks like a UN version issue.  You are running untool 2.8.2.  Which means that you need to be on version 5 of the UN.
The documentation is here:
https://solutions.arcgis.com/utilities/help/utility-network-automation/tool-reference/apply-asset-pa...
Hope that helps!
SMW_GIS
New Contributor III
Thanks for your response. Really appreciate it. I went and  checked and it looks like my UN is in version 5 already.
MikeMillerGIS
Esri Frequent Contributor
This field should be 2000 characters.  How did it get to be 64?  Are you applying this asset package to a new UN or one that has been around a while?
SMW_GIS
New Contributor III
Hi Mike. This is a new UN that was staged using untools 2.8.2.  I'm trying to apply an asset package from version 2.7.  I tried upgrading the asset package and it said it was already at the latest version.
MikeMillerGIS
Any chance you could send me the asset package and the target un so I can see what is going on? mmiller@esri.com
SMW_GIS
New Contributor III
Hi Mike. Unfortunately I'm not able to share the project work we have. I heard from our ESRI rep that it is a known bug that they're looking into.  Thanks for your input though.
