While there is a property of your spatial reference you can adjust that will do this (the XY Tolerance / Resolution), the best practices approach is considered to keep the default parameters of your spatial reference and correct your data.
Ideally this data would be corrected during data conversion or prior to loading your data and enabling your topology. There are many tools and techniques to identify nearly-coincident datasets, but one of the simpler tools I've found to identify these issues is to generate a near table and look for multiple matches within a reasonable distance (1 meter / 1 foot at most).
