Hello ESRI Community,
Our GIS consultation company is currently engaged in a project for an electric generation company, let's call it 'X,' aiming to establish a centralized Geodatabase with a Utility Network (UN). This UN will cater to generation, transmission, and distribution sectors, with X managing the build, design, configuration, and administration on its server.
Here's the challenge: X is working with 10 distribution companies and a transmission company, each needing access only to their specific geographical area within the UN. The added complexity is that these companies will be conducting offline editing in the field, synchronizing edits back to X's server at predefined times.
After extensive research, I haven't found a clear-cut workflow for offline utility network editing in such a multi-company, offline environment. I'm reaching out to the ESRI community to seek insights and recommendations for the best workflow in this scenario.
Specifically:
- What strategies have you successfully employed for configuring a centralized UN for multi-company use?
- Are there best practices for enabling offline editing in designated geographical areas within a UN?
- How can we efficiently synchronize edits from multiple companies back to the central UN maintained by X?
I've already explored options such as replica creation (not supported in branch version) and offline editing tools (missing UN concepts) no rules, terminals or any UN benefits such all UN features classes without the UN dataset, even after Sync to UN service the edits were made in offline version that violence the UN rules weren't detected as errors. Your experiences and suggestions would be immensely valuable in navigating this unique project.
