I have an UN Electric Network set up with multiple Subnetworks and I'm running into an y issue where I have a a transformer and LV lines that it is connected to it not updating correctly after running the Update Subnetwork tool.
What I did is I had a transformer connected to Subnetwork A and then I deleted the MV line making that connection and created a new MV line that connects it to Subnetwork B. Than I ran the Update Subnetwork tool. In the field "subnetwork name" instead of seeing the Subnetwork B name listed for both the transformer and all connecting LV lines I now see Subnetwork A:Subnetwork B.
I have done this before and it usually just changes the subnetwork name to the new one and no longer lists the old name. I have checked the Connected to, Contained within, and Connected to edge associations of the transformer and there is none. The new MV Line only shows Subnetwork B. If I move the old transformer where it is no longer connected to anything and create a new transformer and LV line at this location. The OLD items retain Subnetwork A info instead of going Unknown and the New features only have Subnetwork B. I really don't want to have to redraw the transformer and all LV Lines and Devices connected to the transformer if I don't have to.
Has anyone else run into this issue and have a fix?
