That's handy but just doesn't cut it (pun intended). My users want a simple Ctrl+C just like how Excel works. Here's an extension I wrote to illustrate.<?xml version="1.0" encoding="utf-8"?>
AttributeTableWidget extension for ArcGIS Flex Viewer 3.2
Adds copy feature to Attribute Table via keyboard and right-click menu.
To use, configure the AttributeTable widget and substitute this file for "AttributeTableWidget.mxml" in your config.xml
<AttributeTable:AttributeTableWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:AttributeTable="widgets.AttributeTable.*"
widgetConfigLoaded="basewidget_widgetConfigLoaded()">
<fx:Script>
<![CDATA[
import com.esri.ags.Graphic;
import com.esri.ags.components.AttributeTable;
import flash.events.ContextMenuEvent;
import spark.components.NavigatorContent;
/** Listen for new AttributeTables being added to viewStack */
private function basewidget_widgetConfigLoaded():void
viewStack.addEventListener(ChildExistenceChangedEvent.CHILD_ADD, childAddEvent);
/** Add copy listener and menu item to the new AttributeTable */
private function childAddEvent(event:ChildExistenceChangedEvent):void
var attributeTable:AttributeTable = (event.relatedObject as NavigatorContent).getElementAt(0) as AttributeTable;
attributeTable.addEventListener(Event.COPY, attributeTable_copyHandler);
var contextMenu:ContextMenu = new ContextMenu();
contextMenu.hideBuiltInItems();
var customItem:ContextMenuItem = new ContextMenuItem("Copy selected");
customItem.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, customItem_menuItemSelectHandler);
contextMenu.customItems.push(customItem);
attributeTable.contextMenu = contextMenu;
/** Copy selected rows to the clipboard Excel style */
private function attributeTable_copyHandler(event:Event):void
var rows:Array = [];
for each (var graphic:Graphic in (event.currentTarget as AttributeTable).featureLayer.selectedFeatures)
var newRow:Array = [];
for each (var value:String in graphic.attributes)
newRow.push(value);
rows.push(newRow.join("\t"));
System.setClipboard(rows.join("\r\n"));
/** Dispatch a COPY event when clicked */
private function customItem_menuItemSelectHandler(event:ContextMenuEvent):void
(event.contextMenuOwner as AttributeTable).dispatchEvent(new Event(Event.COPY));
</fx:Script>
</AttributeTable:AttributeTableWidget>
It'd be great to have a similar capability in a future release. This code is retyped, so I apologize in advance for any typos.
