I have an Oracle based SDE feature class with a relate built from a query layer using SQL Server database tables. I would like to be able to open up a pdf file stored in the Blob field of a related record that I can access from the related results tab of the Enhanced Search Widget, in similar fashion to a hyperlink or opening a file. Is this functionality possible with the latest version of the Enhanced Search Widget?
