<?xml version="1.0"?> <configuration> <identifylayeroption>all</identifylayeroption> <identifytolerance>5</identifytolerance> <defaultzoomscale>5000</defaultzoomscale> <keepidentifyactive>true</keepidentifyactive> <returngeometryforzoom>true</returngeometryforzoom> <enablelineselect>true</enablelineselect> <enableextentselect>true</enableextentselect> <enablepolyselect>true</enablepolyselect> <enablemouseovergraphicsinfo>false</enablemouseovergraphicsinfo> <enablemouseoverrecordinfo>false</enablemouseoverrecordinfo> <enablegraphicclickinfo>false</enablegraphicclickinfo> <usemaptime>false</usemaptime> <infoautoclosemilliseconds>2000</infoautoclosemilliseconds><!-- 2 seconds --> <autoactivatedtool>mappoint</autoactivatedtool><!-- possible values are extent or polygon or mappoint or polyline or nothing --> <excludebasemaps>false</excludebasemaps> <disablepopuplinks>false</disablepopuplinks> <disablelayerdropdown>false</disablelayerdropdown> <disablealllayerschoice>false</disablealllayerschoice> <labels> <zoom2message>Click to Zoom to Point</zoom2message> <identifylabel>Identify</identifylabel> <resultslabel>Results</resultslabel> <descriptionlabel>Use the identify tool to identify features on the map:</descriptionlabel> <pointlabel>Identify by Point</pointlabel> <linelabel>Identify by Polyline</linelabel> <rectlabel>Identify by Rectangle</rectlabel> <polylabel>Identify by Polygon</polylabel> <clearlabel>Clear</clearlabel> <loadinglabel>Loading...</loadinglabel> <removeresultmessage>Remove Result</removeresultmessage> <idfrom>Identify From</idfrom> <noresultsfoundlabel>No Results Found</noresultsfoundlabel> <resultsfoundlabel>Results Found</resultsfoundlabel> <alllayers>All Layers</alllayers> <layersremaining>layers remaining:</layersremaining> </labels> <useproxy/> <layers onlythese="false"> <layer> <name>Property</name> <id>8</id> <url>http://198.167.37.68/arcgis/rest/services/BaseData/MapServer</url> <fields> <field name="PID" /> <field name="FIRSTNAME" /> <field name="LASTNAME" /> <field name="PROPLOC" /> </fields> <links> <link includeinresults="true" field="" alias="" tooltip=""> <linkprefix></linkprefix> <linksuffix></linksuffix> <iconfield></iconfield> <iconprefix></iconprefix> <iconsuffix></iconsuffix> </link> </links> <zoomscale>15000</zoomscale> <forcescale>true</forcescale> </layer> </layers> <symbols> <simplefillsymbol color="0x448ccb" alpha="0.4" style="solid"> <outline color="0x448ccb" alpha="0.8" width="2"/> </simplefillsymbol> <simplemarkersymbol style="circle" size="12" color="0x448ccb" alpha="0.8" xoffset="0" yoffset="0" angle="0"> <outline style="solid" color="0xffffff" alpha="0.8" width="1"/> </simplemarkersymbol> <picturemarkersymbol url="assets/images/i_info.png" height="30" width="30" xoffset="0" yoffset="0"/> <simplelinesymbol color="0x448ccb" alpha="0.8" width="2"/> </symbols> </configuration>
<?xml version="1.0" ?> <configuration> <identifylayeroption>visible</identifylayeroption> <identifytolerance>5</identifytolerance> <defaultzoomscale>5000</defaultzoomscale> <keepidentifyactive>true</keepidentifyactive> <returngeometryforzoom>true</returngeometryforzoom> <enablelineselect>true</enablelineselect> <enableextentselect>true</enableextentselect> <enablepolyselect>true</enablepolyselect> <enablemouseovergraphicsinfo>false</enablemouseovergraphicsinfo> <enablemouseoverrecordinfo>true</enablemouseoverrecordinfo> <enablegraphicclickinfo>true</enablegraphicclickinfo> <usemaptime>false</usemaptime> <infoautoclosemilliseconds>2000</infoautoclosemilliseconds><!-- 2 seconds --> <autoactivatedtool>mappoint</autoactivatedtool><!-- possible values are extent or polygon or mappoint or polyline or nothing --> <excludebasemaps>true</excludebasemaps> <disablepopuplinks>false</disablepopuplinks> <disablelayerdropdown>false</disablelayerdropdown> <disablealllayerschoice>false</disablealllayerschoice> <labels> <zoom2message>Click to Zoom to Point</zoom2message> <identifylabel>Identify</identifylabel> <resultslabel>Results</resultslabel> <descriptionlabel>Use the identify tool to identify features on the map:</descriptionlabel> <pointlabel>Identify by Point</pointlabel> <linelabel>Identify by Polyline</linelabel> <rectlabel>Identify by Rectangle</rectlabel> <polylabel>Identify by Polygon</polylabel> <clearlabel>Clear</clearlabel> <loadinglabel>Loading...</loadinglabel> <removeresultmessage>Remove Result</removeresultmessage> <idfrom>Identify From</idfrom> <noresultsfoundlabel>No Results Found</noresultsfoundlabel> <resultsfoundlabel>Results Found</resultsfoundlabel> <alllayers>All Layers</alllayers> <layersremaining>layers remaining:</layersremaining> </labels> <useproxy><!-- Enter the label of the MapService from the main config.xml --> <!--<proxymapservice label="Imagery" /> <proxymapservice label="Streets" /> --> </useproxy> <layers onlythese="false" /> <symbols> <simplefillsymbol color="0x448ccb" alpha="0.4" style="solid"> <outline color="0x448ccb" alpha="0.8" width="2" /> </simplefillsymbol> <simplemarkersymbol style="circle" size="12" color="0x448ccb" alpha="0.8" xoffset="0" yoffset="0" angle="0"> <outline style="solid" color="0xffffff" alpha="0.8" width="1" /> </simplemarkersymbol> <picturemarkersymbol url="assets/images/i_info.png" height="30" width="30" xoffset="0" yoffset="0" /> <simplelinesymbol color="0x448ccb" alpha="0.8" width="2" /> </symbols> </configuration>
