Robert-
Thanks for the reply. No to long after I posted, I realized that this was in the viewer forum and not the Flex API.
I've been working on trying to compile with the given code into the Flex Viewer SDK. If the this code is in the HeaderController mxml it will compile and show an independent map that I can switch between. I thought maybe to modify the MapSwitcherWidget mxml as well, however the toggle button bar is throwing me.
There is a routine within the last mxml which has a changehandler,
private function tbb_changeHandler(event:IndexChangeEvent):void
ViewerContainer.dispatchEvent(new AppEvent(AppEvent.BASEMAP_SWITCH, mapList[event.newIndex].id));
I'm just not sure how that will convey over to the slider code I provided.
