<configuration> <title>Prioritized Tracts</title> <description><![CDATA[ <br><i><b>Name:</b></i> {TRACTNAME} <br><i><b>GIS Acres:</b></i> {GIS_ACRES} <br><i><b>Salesforce:</b></i> <a href="{SALESFORCE_URL}"> (Link) </a><br>]]></description> <fields> <field name = "GIS_ACRES"> <format usethousandsseparator="true"/> <format precision="0"/> </field> </fields> </configuration>
Re: configuring pop-ups in 3.0:
I'm under the impression that it's best to choose to configure the pop-up using either:
1) the Application Builder via the <description> tag -- I like this option because I can format my text using the HTML tags, OR
2) the XML <configuration> -- I like this option because I can use numeric and date formatting tags on FIELD values.
I cannot see examples of how to either:
1) format date or number FIELDS within the <description> tag, OR
2) format non-field text without the <description> tag
Following an example here, I can create the pop-up via the XML file, using <description> and <field> tags, like this:<configuration> <title>Prioritized Tracts</title> <description><![CDATA[ <br><i><b>Name:</b></i> {TRACTNAME} <br><i><b>GIS Acres:</b></i> {GIS_ACRES} <br><i><b>Salesforce:</b></i> <a href="{SALESFORCE_URL}"> (Link) </a><br>]]></description> <fields> <field name = "GIS_ACRES"> <format usethousandsseparator="true"/> <format precision="0"/> </field> </fields> </configuration>
BUT, if I then view the code inside the Application Builder, all my field formatting gets deleted from the XML (everything below </description>)... this seems risky since I move between App Builder and configuration files.
It seems safer to choose either <description> or <configuration>, rather than mixing the two, but I don't know how to do all the formatting I need using either option.
Any advice is welcome.
Oh, and my pop-up doesn't seem complicated, I need to be able to do these things:
Name: Green Acres (bold/italics formatting on the left-hand column names)
Acres: 2,550 (bold/italics formatting, and the FIELD needs precision and thousandsseparator formatting on its value)
Date Protected: 2/3/2010 (bold/italics formatting, and the FIELD needs date formatting on its value)
<field name="INSTALLDATE" alias="Install Date" visible="false"> <format dateformat="shortDate"/> </field>
Under your fields tag add the following and change it to your data. Make sure to keep it false for visible and pick your dateformat you want but i think you are looking for shortDate.
If you have that field for example INSTALLDATE in your description tag it will format the date using whatever you specified, for example shortDate.
It has worked for me and should work for you as well.
