Displaying Operational Layers in Overview map
397
01-03-2012 08:32 AM
PaulFerro1
New Contributor III
I am using the Flexviewer 2.3.1 and want to display an operational layer on top of my default basemap in the overview window.  Is this possible?
Or does this require modifying the code for overview map widget? Can someone supply me with that code? Thanks!
RobertScheitlin__GISP
geotrekGIS,
Attached is the updated OverviewMapComponent.mxml code that has to replace the out of the box version, and you will have to manually specify your layers, basemap and operational in the OverviewMapWidget.xml as in the example OverviewMapWidget.xml.
PaulFerro1
New Contributor III
Thanks Robert! I am just now seeing this.
So would I need to revert back to 2.3.1 compiled flexviewer in flashbuilder and re-compile?
I currently am working with 2.5 flexviewer code in flashbuilder.
Paul,
   It should be OK with Flex Viewer 2.5. If not just let me know.
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
