esri|InfoWindow { content-background-alpha : 0; background-color : yellow; background-alpha : 0.8; border-style : solid; }
Does anyone know how to change the width of the column for the output results. I see labelwidth changes the column width for the filed name, but would like to widen the output column also.
Thanks.
label.width = 143;Change the 143 to the desired width. In my file it was on line 174.
Miguel,
You are editing the wrong file. You need to be editing the PopUpRendererSkin.mxml. Then you need to know if the popup is configured using the description or individual fields (these are two different code paths).
