I have a web map created to edit a point feature layer. The .msd is created to show labels but the labels do not show up in the web map. Does anyone know how to make labels show up for feature services that are edited by the flex viewer application??
Labels will only work when you are using a "dynamic" type map service they will NOT work if the type you assign in the main config.xml is "feature". So you have to add the map service as type dynamic to get the labels and then also add your FeatureService layer as type feature to get the editing.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote). Follow the steps as shown in the below graphic:
