Quick question: is it possible for the gridview to be the default view for results when a user does a search (as opposed to them having to click on the green button to open it)? Or do I need to use the modifications that let you have datagrid open via the URL?
Hi Jon, Thanks for responding. I have tried <defaultselectionoption> in my XML but its still doing the same. I have tried commenting few lines and its working, but initially its not highlighting the graphical search state when it loads but displays later after performing some operation.
With out modifications to my code the defaultselectionoption in the SearchWidget.xml work fine. Once you have changed code in my widgets I can not guarantee anything...
So far I am loving this widget. If I want to search for a single date what expression should I use in the .xml. Also, would it be possible to search by date range? Thanks!
SQL for searching by dates are specific to the underlying database. So are you talking a SDE map service using SQL Server or Oracle, or maybe a file GeoDb?
