Robert -
I have been configuring the Enhanced Search widget for use in my company's webservices and have a question. I like the ability to define a hyperlink field as part of the data grid, but there doesn't seem to be a way to define a hyperlink for the info pop-up. The grid is great for wide text searches or for spatial searches, but if my field guys know the data record they specifically want to reference then it would be easier for them to open the hyperlink from the info window.
Am I being dense - I have been through the documentation several times and I know the hyperlink functionality is there in the stock "Search" widget with Flex Viewer.
Michael Hanna
Middlesex Water Company
<links> <link alias="REST Services Directory"> <![CDATA[{URL}]]> <icon><![CDATA[assets/images/i_camera.png]]></icon> </link> </links>
I am using the same config file that worked with the enhanced search tool in version 10 of ESRI. Now in 10.1 everything seems to work except that when i hit enter or run the search nothing at all happens. What could be the problem, any suggestions?
Robert,
I did update their applications to version 3.0 FlexViewer, use your perfect Enhanced Search Widget version 3.0.
The widget works great, grid is great, the uncompiled version can not find where I change his position. Currently at the center, I need the bottom.
Greeting
Edin Z.
Robert,
i have probably a stupid question but here goes, in the search widget it pulls from a service thereby returning a numeric value when called from our system such as a Sub Type Code, is there any way to configure it so it returns the coded value like the Identify widget does? i know that the Idnetify widget does not use a service to return values. i have attached a screen cap of the two widgets on the same feature. Notice the Sub Type Code Field on each.
[ATTACH=CONFIG]15399[/ATTACH]
