Enhanced-Search-Widget-for-FlexViewer Part II
88463
552
04-19-2012 08:03 AM
RobertScheitlin__GISP
All,
   I am pleased to announce the next release of my eSearch Widget.
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
Version 2.5.1.7 - 4/19/2012
* Added ability to search (flat/standalone/no geometry) tables.
* This time all Zooming uses the same scaling (popup, datagrid, widget results, zoom to all).
* Added Relates icon/button to datagrids so that you can click on it in the datagrid to
  open relates choice dialog.
* Move all skins to a skins package for cleaner organization.
* Links that are not associated with a field now work.
* Ability to disable the relates tab in the fixed widget is now configurable.
AndyCowx1
Andy,
   This thread is dealing with the Enhanced Search Widget and not the OTB Search Widget. But to answer your question what you are attempting can not be done with out writing code to handle the Query of two specific REST endpoints and then more code to handle displaying the results of both querys.
Robert,
That's what I figured. Was kinda hoping that the Enhanced Widget might offer that functionality.
No biggie.
Andy
RhettZufelt
MVP Frequent Contributor
Andy,
I know this isn't exactly what you are after, but the eSearchWidget will let you configure multiple expressions and values within it.
Would probably be cleaner to just have a dropdown on the eSearchWidget to pick the desired layer/search rather than two separate widgets.
R_
ChrisA
Chris,
   It is hard to tell, you might have removed something that is needed in the eSearchWidget.xml file. Can you search your PC for the eSearchWidget.xml file and zip it and attach it for review?
Thanks Robert. I attached the xml file for your review.
Chris
Chris,
   Seems like you sent me the wrong file (right name and all), but this one is unaltered from the original that is included in the download and does not contain any of your changes.
ChrisA
Chris,
Sorry about that.  Here's one I modified.  I removed all layers but one, added my attributes and removed the tables.
Chris
JonFisher
I just upgraded to the FlexViewer 3.1 and installed the new eSearch widget 3.1.6. I'm hoping to use the non-fixed setup (as I have in the past), but I can't get the grid to show up at all. Here's my app using Robert's default config file (which doesn't show the grid either): http://maps.tnc.org/coredata_new/index.html?config=esearch.xml
And here's the app pointing to my own data (still no grid): http://maps.tnc.org/coredata_new/
Do I have something configured wrong, or did the widget switch to only working with the fixed setup?
thanks,
Jon
Jon,
   You simply forgot to change the <floatorfixed>fixed</floatorfixed> to float.
JonFisher
Jon,
That did it, thanks! I'm not sure how I missed that, I must be even more tired than I thought...
AaronMielke
Robert,
Am I missing something or is there not a compiled version of the Enhanced Search Widget version 3.1.6?  Any chance you could post a compiled version.
Aaron
Aaron,
   Yes you are definitely missing something. On the download page you need to scroll down to the Code Attachment                                        eSearch.zip  Download
