Hi Robert!
Sorry I have not been able to reply to your last post until now - got pulled away to work on some other things. Thank you, so much, for getting back to me! Before I contacted you, I had changed some of the defaults on the 'Coating' field to see if it made a difference and I think that's why nothing was showing up for the 'Coating' field. Below is a copy of what it should look like. This feature is sub-typed and domains are assigned by sub-type. Do you think that could be part of why it's not recognizing the domains correctly? The feature itself has the sub-type defaulted to our PTR Plastic main type and the coating for our plastic main subtype is defaulted to '13', which is the only value showing up. Just wondering if possibly removing all of the defaults might make a difference or if you have ever seen problems with sub-typed features having multiple domains for one field, cause problems.....
Layer: DIMP Main Risk Total (ID: 1)
Name: DIMP Main Risk Total
Display Field: DIMP_Risk_TotalM
Type: Feature Layer
Geometry Type: esriGeometryPolyline
Description:
Definition Expression:
Copyright Text:
Default Visibility: false
MaxRecordCount: 1000
Supported Query Formats: JSON, AMF
Min Scale: 200000
Max Scale: 0
Supports Advanced Queries: true
Supports Statistics: true
Has Labels: false
Can Modify Layer: false
Can Scale Symbols: false
Extent:
XMin: 847998.3831069246
YMin: 1.3449008955802359E7
XMax: 2571571.339169342
YMax: 1.5469996786522023E7
Spatial Reference: PROJCS["WGS_1984_UTM_Zone_12N",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",1640416.666666667],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-111.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Foot_US",0.3048006096012192]]
Drawing Info:
Renderer:
Class Breaks Renderer:
Min. Value: 0.0
ClassBreakInfos:
Class Maximum Value: 909616
Label: 0 - 909616
Description:
Symbol:
Style: esriSLSSolid
Color: [56, 168, 0, 255]
Width: 4
Class Maximum Value: 1819232
Label: 909617 - 1819232
Description:
Symbol:
Style: esriSLSSolid
Color: [139, 209, 0, 255]
Width: 4
Class Maximum Value: 2728848
Label: 1819233 - 2728848
Description:
Symbol:
Style: esriSLSSolid
Color: [255, 255, 0, 255]
Width: 4
Class Maximum Value: 3638464
Label: 2728849 - 3638464
Description:
Symbol:
Style: esriSLSSolid
Color: [255, 128, 0, 255]
Width: 4
Class Maximum Value: 4548080
Label: 3638465 - 4548080
Description:
Symbol:
Style: esriSLSSolid
Color: [255, 0, 0, 255]
Width: 4
Transparency: 0
Labeling Info:
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Type ID Field: MaterialType
Fields:
DIMP_Risk_TotalM ( type: esriFieldTypeInteger , alias: DIMP Main Risk Total )
DIMP_Risk_TotalM_NoExcavation ( type: esriFieldTypeInteger , alias: DIMP Main Risk Total (No Excavation) )
MJ ( type: esriFieldTypeInteger , alias: MJ )
PROJECTID ( type: esriFieldTypeInteger , alias: Project ID )
ORIGINSTDATE ( type: esriFieldTypeDate , alias: Original Install Date , length: 8 )
INSERVICEDATE ( type: esriFieldTypeDate , alias: In Service Date , length: 8 )
NOMINALDIAMETER ( type: esriFieldTypeSmallInteger , alias: Diameter , Coded Values: [-1: Unknown Verified] , [0: Unknown] , [1: 1] , ...10 more... )
MATERIALTYPE ( type: esriFieldTypeInteger , alias: Material )
GRADE ( type: esriFieldTypeString , alias: Grade , length: 20 , Coded Values: [2306: 2306] , [2406: 2406] , [2708: 2708] )
COATINGTYPE ( type: esriFieldTypeSmallInteger , alias: Coating , Coded Values: [13: N/A] )
CATHSYSID ( type: esriFieldTypeString , alias: Cathodic System ID , length: 12 )
RECONDITIONED ( type: esriFieldTypeSmallInteger , alias: Reconditioned , Coded Values: [4: N/A] )
BELTLINEINDICATOR ( type: esriFieldTypeSmallInteger , alias: Beltline Indicator , Coded Values: [-1: Unknown Verified] , [0: Unknown] , [2: YES] , ...2 more... )
COUNTYNAME ( type: esriFieldTypeString , alias: County , length: 50 )
STATENAME ( type: esriFieldTypeSmallInteger , alias: State )
CITYNAME ( type: esriFieldTypeString , alias: City , length: 50 )
OPAREA ( type: esriFieldTypeString , alias: Operation Area , length: 8 )
REGIONOFFICENAME ( type: esriFieldTypeString , alias: Region Office , length: 50 )
REGIONOFFICECODE ( type: esriFieldTypeString , alias: Region Office Code , length: 20 )
REGIONNAME ( type: esriFieldTypeString , alias: Region , length: 50 )
ConsequencesM ( type: esriFieldTypeInteger , alias: Consequence Total )
Risk_Factor_TotalM ( type: esriFieldTypeInteger , alias: Risk Category Total )
Risk_Factor_TotalM_NoExcavation ( type: esriFieldTypeInteger , alias: Risk Category Total (No Excavation) )
Risk_CorrosionM ( type: esriFieldTypeInteger , alias: Corrosion Risk )
Risk_EquipmentFailureM ( type: esriFieldTypeInteger , alias: Equipment Failure Risk )
Risk_ExcavationDamageM ( type: esriFieldTypeInteger , alias: Excavation Damage Risk )
Risk_IncorrectOperationM ( type: esriFieldTypeInteger , alias: Incorrect Operation Risk )
Risk_MaterialM ( type: esriFieldTypeInteger , alias: Material Risk )
Risk_NaturalForcesM ( type: esriFieldTypeInteger , alias: Natural Force Risk )
Risk_OtherOutsideForcesM ( type: esriFieldTypeInteger , alias: Other Outside Force Risk )
Risk_WeldJointFailureM ( type: esriFieldTypeInteger , alias: Weld Joint Failure Risk )
TopSystemScoresM ( type: esriFieldTypeString , alias: Top System Scores , length: 5 )
TopSystemScoresMNoExc ( type: esriFieldTypeString , alias: Top System Scores (No Excavation) , length: 5 )
TopSystemScoresMNoBelt ( type: esriFieldTypeString , alias: Top System Scores (No Beltline) , length: 5 )
TopSystemScoresMNoExcNoBelt ( type: esriFieldTypeString , alias: Top System Scores (No Exc) (No Belt) , length: 5 )
TopRegionOfficeScoresM ( type: esriFieldTypeInteger , alias: Top Region Office Scores )
TopRegionOfficeScoresMNoExc ( type: esriFieldTypeInteger , alias: Top Region Office Scores (No Excavation) )
TopRegionOfficeScoresMNoBelt ( type: esriFieldTypeInteger , alias: Top Region Office Scores (No Beltline) )
TopRegionOfficeScoresMNoExcNoBelt ( type: esriFieldTypeInteger , alias: Top Region Office Scores (No Exc) (No Belt) )
Shape ( type: esriFieldTypeGeometry , alias: Shape )
OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID )
Types:
Domains:
COATINGTYPE:
Inherited
NOMINALDIAMETER:
Inherited
BELTLINEINDICATOR:
Inherited
RECONDITIONED:
Inherited
GRADE:
Inherited
Name: Thin Wall Rocket Tubing
Domains:
COATINGTYPE:
Coded Values: [-1: Unknown Verified] , [0: Unknown] , [2: Bare] , ...14 more...
NOMINALDIAMETER:
Coded Values: [-1: Unknown Verified] , [0: Unknown] , [2: 2] , ...4 more...
BELTLINEINDICATOR:
Inherited
RECONDITIONED:
Coded Values: [0: Unknown] , [2: Yes] , [3: No]
GRADE:
Coded Values: [N/A: N/A]
Domains:
COATINGTYPE:
NOMINALDIAMETER:
Coded Values: [-1: Unknown Verified] , [0: Unknown] , [4: 4] , ...2 more...
BELTLINEINDICATOR:
Inherited
RECONDITIONED:
GRADE:
Domains:
COATINGTYPE:
NOMINALDIAMETER:
Coded Values: [-1: Unknown Verified] , [0: Unknown] , [1: 1] , ...20 more...
BELTLINEINDICATOR:
Inherited
RECONDITIONED:
GRADE:
Domains:
COATINGTYPE:
NOMINALDIAMETER:
BELTLINEINDICATOR:
Inherited
RECONDITIONED:
GRADE:
Domains:
COATINGTYPE:
Inherited
NOMINALDIAMETER:
Inherited
BELTLINEINDICATOR:
Inherited
RECONDITIONED:
Inherited
GRADE:
Inherited
