esearch Enhancement
899
5
07-25-2012 08:25 AM
AnthonyGiles
Robert,
How hard would it be to have a check box on the graphical input that say's something like 'include text input to search' , which when selected appends any text input query you have set up on the other tab to the graphical search.
In essence you would be able to combine the text and graphic search together.
Hope that makes sense,
Regards
Anthony
P.S. Still using V2.5
RobertScheitlin__GISP
Anthony,
   This is now part of Version 3.0.2
Anthony,
   I will add it to the enhancement list, but I don't enhance older versions of my widgets so if it make the cut it will be added to the 3.0 version not the 2.5. That being said I could comment it so that you would know what to change in the 2.5 version.
AnthonyGiles
Cheers Robert
Anthony,
AnthonyGiles
Thanks Robert,
Are the changes you made easy enough to incorporate into v2.5
Anthony
Anthony,
   I have tried to comment all the changes for that feature in the attached.
PS. you will need the blank.png from the new version of the widget in your eSearch/assets/images folder.
