Fail to Recompile Flex Viewer Source
4127
01-27-2015 06:39 PM
tommykurniawan1
New Contributor III
Hi All,
I've just found out fail ( 100 error ) to recompile Flex Viewer source ( version 3.6 and 3.7 ),
october last year ( 4 month ago ) every things works ok with no problem..
Is Anyone has got the same problem ? Or any suggestion for this.
Thanks - Tommy
RobertScheitlin__GISP
Tommy,
   So I have to ask again did you follow the instructions for adding the agslib-3.7-2014-11-06.swc to the libs folder? You did not have to do this in older versions of flexviewer as the swc was included in the zip.
Tommy,
  1. What version of Flash Builder are you using?
  2. What version of the Adobe Flex SDK are you compiling with?
  3. Did you remember to add the ArcGIS Flex API swc to the libs folder before attempting to compile?
tommykurniawan1
New Contributor III
Robert,
Thanks for fast reply,
I try using Flash Builder 4.6 and 4.7.
The methods is importing as flex viewer source project ( SDK/ SWC
included is 4.6 ).
tommykurniawan1
New Contributor III
Robert,
Old code 'flexviewer-2.3.1-src.zip' works fine, but this old code one.
Tommy,
tommykurniawan1
New Contributor III
Robert,
Finaly i found the solution, yes SWC not included in the package.
Now working fine.
Thanks for the reply.
