Dave,
What does your layer element in the main config.xml look like for this map service that is giving you this issue? Are you just reaching your max return features limit for that map service (by default it is set to 1000)?
Thanks for the response. I am very new to all of this so please forgive my ignorance. In looking over the config files I see this with respect to the service I am putting the data into.
<layer label="PFS Survey Pending" type="dynamic" visible="false" imageFormat="png32" alpha="1" url="http://pam.petro-fs.com/ArcGIS/rest/services/PFS/PFS_Survey_v3_Pending/MapServer"/>
here is all of the config stuff for the web app I am building
<?xml version="1.0" ?>
- <configuration>
<title>Bear Tracker</title>
<logo>assets/images/logo.png</logo>
- <style>
<colors>0xffffff,0x333333,0x101010,0x0,0xffd700</colors>
<alpha>0.8</alpha>
<font name="Comic Sans MS" />
<titlefont name="Arial" />
<subtitlefont name="null" />
</style>
- <!-- replace the following url with your own geometryservice
<geometryservice url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" useproxy="false" />
- <widgetcontainer layout="float">
<widget icon="assets/images/i_target.png" label="Find an address" config="widgets/Locate/LocateWidget.xml" url="widgets/Locate/LocateWidget.swf" />
<widget icon="assets/images/i_draw2.png" label="Draw and Measure" config="widgets/Draw/DrawWidget.xml" url="widgets/Draw/DrawWidget.swf" />
<widget icon="assets/images/i_print.png" label="Print" config="widgets/Print/PrintWidget.xml" url="widgets/Print/PrintWidget.swf" />
<widget url="widgets/LayerList/LayerListWidget.swf" config="widgets/LayerList/LayerListWidget_1.xml" label="Layer List" icon="assets/images/i_layers.png" />
<widget url="widgets/Legend/LegendWidget.swf" config="widgets/Legend/LegendWidget_1.xml" label="Legend" icon="assets/images/Legend32.png" />
<widget url="widgets/Search/SearchWidget.swf" config="widgets/Search/SearchWidget_1.xml" label="Search" icon="assets/images/i_search.png" />
</widgetcontainer>
<subtitle>Pipeline</subtitle>
<widget url="widgets/Navigation/NavigationWidget.swf" config="widgets/Navigation/NavigationWidget.xml" left="10" top="50" />
<widget url="widgets/OverviewMap/OverviewMapWidget.swf" config="widgets/OverviewMap/OverviewMapWidget.xml" right="-2" bottom="-2" />
<widget url="widgets/MapSwitcher/MapSwitcherWidget.swf" config="widgets/MapSwitcher/MapSwitcherWidget.xml" right="20" top="55" />
<widget url="widgets/HeaderController/HeaderControllerWidget.swf" config="widgets/HeaderController/HeaderControllerWidget.xml" left="0" top="0" />
- <map esrilogovisible="true" openhandcursorvisible="true" scalebarvisible="true" zoomslidervisible="false" wraparound180="true" addarcgisbasemaps="true" initialextent="-11567139.31931013 6102416.403950664 -11433298.082782969 6172356.284831506" wkid="102100" top="40">
- <basemaps>
<layer type="tiled" label="Imagery" icon="https://www.arcgis.com/sharing/rest/content/items/86de95d4e0244cba80f0fa2c9403a7b2/info/thumbnail/tempimagery.jpg" url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer" visible="true" />
</basemaps>
- <operationallayers>
<layer type="dynamic" label="PLSS SupportingData" url="http://pam.petro-fs.com/arcgis/rest/services/SupportingServices/PLSS_SupportingData/MapServer" visible="true" />
<layer type="dynamic" label="ND SupportingData v2" url="http://pam.petro-fs.com/arcgis/rest/services/SupportingServices/ND_SupportingData_v2/MapServer" visible="true" />
<layer type="feature" label="Tracts" url="http://pam.petro-fs.com/arcgis/rest/services/PFS/PFS_Survey_v3_Pending/MapServer/5" popupconfig="popups/PopUp_4.xml" mode="snapshot" visible="true" />
<layer type="feature" label="Kodiak Route Export 100312" url="http://pam.petro-fs.com/arcgis/rest/services/PFS/PFS_Survey_v3_Pending/MapServer/4" visible="true" />
<layer type="feature" label="linework" url="http://pam.petro-fs.com/arcgis/rest/services/PFS/PFS_Survey_v3_Pending/MapServer/3" visible="true" />
<layer type="feature" label="field points" url="http://pam.petro-fs.com/arcgis/rest/services/PFS/PFS_Survey_v3_Pending/MapServer/2" popupconfig="popups/PopUp_5.xml" mode="snapshot" visible="true" />
</operationallayers>
</map>
</configuration>
I hope I am sniffing in the right spot here.
Thanks
