Hi all,
We have installed the upgrade of FP -> 15.0.0.189 and the flex viwer seems to work but when we use the identy widget of Robert, the link to a directory on our server don't work. We see the icon but nothing happen when we click on it.
We use FV 3.3.
Is there someone that could help me?
Thabnks in advance
David
Solved! Go to Solution.
David,
UNC path links were broken in Flash Player dues to tightened security long before FP15. You need to use real http links as you can NOT use UNC Paths anymore. I have just tested FP15 and my identify widget using true http links and everything is fine.
David,
Thnak you very much Robert. Adding "file://" to \\myserver\..." did the trick.
